Debris in heater blower fan
Hyper Henry
7:09 PM
Ontario,Canada
Did a search and can't seem to find any info. My 67 Coronet has what sounds like debris in the heater blower fan. Is there a way to get at it without having to drop the entire heater assy?? Looks like there is backing plate type thing that can be taken off the back??
You might be able to remove the blower motor, if you can you can remove debris through hole.
If you run the blower motor eventually little bits will come through either on the floor or up at the defroster. Removing isn't so bad. One stud and nut toward the passenger and 3 studs through the firewall. Can be done single handed.
