- 9:10 PM
- Jan 14, 2009
- Shoreline, Washington
Ok, one more time, 90 percent of what is posted here, I can’t/don't disagree with. Remaining points of contention, first, there are no published ratings for these ammeters. The cross-section of the brass ammeter internal bus, at its narrowest point, roughly equates to the cross-section of 8-6 ga solid core copper wire, the ammeter is not going turn into a fuse before all supporting 12ga wiring, terminal connections, Packard terminals light up first under the described extreme case scenario. With good tight stud connections, these original passenger car ammeters from this time will handle a great deal of current for short periods of time, will not turn into a fuse by any means before all other related stock conductors in that circuit burn up first.Jumper cables.
Crank it over and the engine goes into high idle once it starts and that 120+ amps that the alternator is capable of pumping out goes THROUGH the ammeter to that battery that is sucking it through the 60-rated ammeter and, thus, turning it into a fuse.
If you have problems with your ammeter circuit, that ain't all that's wrong.
All of the power to run your car comes through that bulkhead connector and, before the ammeter, it splits off and services all of the vehicle's circuits. The only current flowing through the ammeter after you replace the voltage lost during starting the vehicle is just a trickle charge on the battery.
Bypassing the alternator circuit with an under-the-hood shunt does absolutely NOTHING to remedy the loss of current-carrying capacity of the marginal bulkhead connectors.
You haven't fixed the REAL problem, you've just kluged up a symptom-elimination patch.
Every electrical system in the vehicle depends on good, tight bulkhead connections.
Loose and dirty bulkhead connections get hot with use.
Every time you use the heater, wipers, headlights, etc., you are deriving your current through these faulty bulkhead connections.
The ONLY thing you have eliminated with the shunt is the ammeter itself which wasn't the problem in the first place because ALL of your system loads are tapped into the alternator circuit BEFORE passing through the ammeter.
The ONLY time current passes through the ammeter is:
(1) when the engine ISN'T running in which case the battery is supplying the current.
(2) the alternator isn't charging, again, in which case the battery is supplying the current.
(3) when the alternator is replenishing the voltage drained off during start-up and,
(4) once that has stabilized, the voltage regulator keeps the alternator output just barely over the the current being used by ALL of your electrical systems and is trickle charging your battery.
You DON'T need an ammeter to run a charging system. You can use a volt meter, instead, to monitor the condition of the charging system. That's why Powermaster exists. Their method of connecting the alternator directly to the battery DOES work and is a valid method for their application but, and that's a big "but" if you try and use their technology on an older ammeter style circuit as a repair for dim headlights, slow wipers, etc., you had better make damn sure that the power getting inside the cabin is not being compromised by worn, overheated and/or corroded bulkhead connectors.
Adding your own shunt or switching to a high amperage Powermaster alternator is not a valid substitute for inadequate bulkhead connections. You also have to address to real reason for the "upgrade" and replace the brass terminals in the bulkhead connector. (or replace the under dash and engine bay harnesses)
Basic charging system with an ammeter.
The shunt does NOTHING to repair the poor connections in the bulkhead connector and the current STILL has to pass through that connector regardless of whether there's a home made shunt or a Powermaster alternator.
At the risk of repeating myself yet again, the described battery to alternator shunt wire, overlaying the original stock charge path, not only shunts the ammeter, it shunts the entire stock charge path, removes the bulk of the charging current off the bulkhead Packards, leaving only the vehicle loads on the Packards but now splits the vehicle loads between the two sets of Packards, reducing current loads though the Packards (good thing). The REALLY BAD THING is it also shunts the stock circuit protection (the fusible link) for all remaining stock unfused 12ga wiring and components. Raises the overcurrent limiting level for the entire system by many fold thanks to Kirchhoff's current divider rule. In the event of a short circuit anywhere in the system, wires will burn with that shunt wire in place.
Once more, Post #32
