Carlisle Trippy
can anyone help me with this one? my 72 charger ralley clusters gauge lights seem dim. I have replaced switch-replaced bulbs- dimmer is in high position. cant get this one?????? Please help Mopar gods!!
Check your ground. The rallye cluster has a ground wire that plugs in just above the voltage limiter and runs to a screw on the bottom left of the dash that can loosen up or get disconnected over time.
Thank youIt's directly above the radio. Little square device. There is a spade above it where the screw holds it on for the ground wire.
Compared to todays "dashes" I think the old stuff just looks dim. You can get green led's that keep that vintage green look but are much brighter.
