Belvedere-II
The spindles and calipers are 73-76 A body, and the first master cylinder I got was for a 71 B body with a very small front (rear brake) reservoir. We had problems, so I got a 75 A body "power brakes, front disc, rear drum" master cylinder. I have an adjustable proportioning valve in-line with the rear brakes and even adjust out fully (less brake) the rear brakes drag. The drum slides off without much effort, and the shoes are in good shape. The rear wheel cylinders are new (65 B body replacemnt), and the problem I'm having is that when I hit the brakes hard, the fronts don't lock up at all.
On level ground, if I come to a stop by normal means... not pushing the brakes hard... the car does stop okay and it doesn't seem to be a problem. If I brake hard and come to a stop, when I take my foot off the brake pedal the car will not move forward under idle until after a couple seconds (did this with the other master cylinder, too.
Since the car had a single reservoir and 4 wheel drums, I'm guessing that the tee, or 'distribution block', for the brake lines was just a block with four tapped holes (single inlet, RF, LF, Rear lines) and that it wasn't a "vavle" of any sort. Would that be correct? Or would you think that distribution block had something in it to adjust brake line pressure between front and rear?
