Disk brake conversion
CaptainAtom
9:15 AM
Tucson, A
Hey everyone, I'm doing a rear disk brake conversion on my 67 Charger and need some help because I'm not familiar with this stuff at all.
https://www.classicindustries.com/p...2WXdEHUNGSjqCADezssaAhxjEALw_wcB&gclsrc=aw.ds
https://www.jegs.com/i/JEGS/555/631...oc4C6BEdTjpKjMxSMLkWfSSvqomt9lmcaAtAiEALw_wcB
I'm looking at going with either of these kits for an 8 3/4 rear end. So from the research I've done and casting numbers on the axle I'm pretty sure that's what I have, but if anyone can confirm that from these pictures it would be appreciated.
(This is what I have with the tire taken off)
Now the brakes from Jegs mentions needing to measure the axle hub flange to make sure the rotors will fit on the axle. The problem I'm having is that what's under the tire doesn't look like the picture that shows how to measure it to make sure the rotors will fit. However the picture does look like rotors that are already installed on the axle but since I'm a novice when it comes to all this I can't say for sure.
I really want to make sure I get the right kit and do it right the first time, so if anyone can let me know if what I'm pointing at is this picture is what I need to measure the inside diameter of, or if it's the thing in the picture that has my hand in it, or if I'm missing parts or just anything that I might need to know it would be greatly appreciated.
Found this setup. Read below for further instructions. Seems like a pretty cool setup to use off the shelf parts.
With these brackets you can easily and very economically convert your existing drum rear to disc brake with our AutoCAD engineered brackets. We make these brackets right here in the USA with state-of-the-art CNC laser machinery for excellent fit and finish. The inner section is made from 11 gauge steel, the same as you existing drum backing plate, so tapered bearings will not need to be shimmed.
This setup uses Toyota Previa rotors and T-Bird rear calipers, giving you an excellent affordable system. It matches your car's hydraulics very well, and it will fit inside Mopar drum 14" and up rims.
Note you will need to machine the axle flange to fit inside the rotor and that the rotor may need the pilot hole opened up.
