Disk brake help please
goose69
4:24 AM
portland,or
I have a 1966 Belvedere Im working on and robbed a disk brake set up off a 1973 satellite. I was able to get everything including the proportioning valve but not the master cyl. I wondered which master cyl you guys would suggest keeping in mind it will have NO power assist. I've seen some newer aluminum ones used but not sure what they came off of. This still has the 4 hole mount but would entertain changing to a 2 hole mount if it's better. A suggestion of a car/ truck to rob them from would be the best for me, if not any suggestions are greatly appreciated.
Thanks again!
Sounds like a good score. I think any Disc brake Master cylinder wil serve you well
I agree with this. It shouldn't mater if the master is for a power brake or non power brake booster. I would pick up one for a 73 dart with disk brake.
I just put disc brakes on my 1967 Coronet and I think I used a master cylinder for a 1976 360 Dart with disc and non-power.
Thanks again!
Rockauto.com $50
