Distributor bushing
Vicb440
2:13 AM
Long Island, New York
Hi. I have a Chrysler distributor PN 2875116. Is the bushing from pioneer on 839007 compatible. It’s different than the factory one with the rubber on the outside of it. And how to I get out the old one. Do you hammer in a punch from the bottom or is that going scrape the housing. I could use more info. Thanks.
FSM should have it all in there around section 8-27. Have a pic of the rubber one? Never seen that. You can punch out the bushings then TAP the new ones in gently since I doubt you have a tool for it. Then Ream and burnish it and that should be it.
