flatheadgary
i put a 360 4 barrel intake manifold on my 318 and am having a problem on were the vacuum pot is supposed to point at. with the distributor shaft slot pointing at number 1 cylinder, when i put in the distributor, it either points at the 5 cylinder or toward the firewall and right fender. as the intake runner is quite large it can not be turned to any other point with out hitting the runner. which way should i point it?
