Distributor-stay with points or go electronic?
Pa's Sat
11:04 PM
Hickman
If I go electronic does anything else change, like no coil, or should I stay with the old system of points. The old distributor is bad so reeds replacing now. Also had a bad thing happen, when the distubtor was out I dropped a small nut down the hole! Tried fishing with a magnet to no avail. Other suggestions? Looks like I will have all winter to get it going. UGH
Good luck finding the nut. You don't give much info on your car.. What engine you have ?
Unless your car is a stock restoration, I recommend electronic. I am a fan of the HEI conversion.
Mike
