22” Radiator - Standard Cooling - No Air - No Performance Axle
3443938 is the correct service replacement number for core stamped numbers 3443961 & 3443962 (71 B & E body 22" 383 - no air).
If you have a broadcast sheet, look at line 3 (green line) under "RAD"... if it says 61 then your car came with 3443961; 62 would call for the 3443962. 61 Auto 62 Manual
Your correct fan shroud should bee part # 2998328
Radiators are very hard to come by
Fan Shrouds are reproduced
Fan Shroud Brackets are reproduced
Yes on the factory 7 blade fixed fan with this radiator , no fan clutch
