Does this sound right?
Heimedw
8:05 PM
Ontario
I call comp cam to double check what push rod I need for my fuel pump and they said it needs a bronze tip push rod? It's a hydrolic roller cam from comp. the reason I'm a little unsure is the part number on the cam is a custom grind and they couldn't find it.
I'm pretty sure that Comp is still grinding their big block Mopar hydraulic rollers on steel billets. Therefor the bronze tipped fuel pump push rod is correct.
