Drag pack intake manifold
Dreadl0ck
9:31 PM
Sweden
Anyone of you with gen 3 hemis looked at the drag pack intake manifold? What would be the throttle body options to mount on it? I think Nate @ Demon has played with it but can't find any specific mounting information other than the drag pack 4 barrel throttle body.
What if anyone would want to run EFI but with the drag pack manifold?
It comes in a 4150 and 4500 flange. You can run an elbow and use an EFI style throttle body it you wanted. There are stand off to mount injector bungs. It can turn into a pretty pricey adventure by the time you are done.
Question I ask is that it could be a good looking setup with a top mounted tb together with a circular air filter - to mimic the looks of the wedge engine which the car came with. But as you said - elbow needed will kill the look and probably not worth the money that would go into a project like that. Thanks
They have the original and a short version (2 inches shorter than the original with less plenum volume). The short one should work with a standard 4150 style tb (they're considerably shorter than a 4150 carb) and standard breather without hood mods. With fuel injectors and rails installed they look like a fuel injected Victor manifold. Gotta perform better than that gaping hole they call the mod man from indy.
Four barrel tb has much better airflow control than the beer can one barrels.
