Drive shaft specifications
Moparfiend
11:18 PM
HOT
Does anyone know how I can determine the drive shaft specifications for my car? Part number? I know I can measure the length etc but let’s assume I don’t have one.
1970 Plymouth Sport Satellite small block with a A904 trans.
If no answer I can measure mine from the 70 charger. 318/904- 8 1/4. You did not say what your rearend was.
It’s the same 8-1/4. I put a 340 in but should be identical. Let’s see if anyone chimes in to protect your knees!
The original driveshaft in a 1970 Sport Satellite with 318 and A904 transmission is 55.47" long, part number 2883791.
Note that the 1970 Charger has a one inch longer wheel base (117") than the Satellite (116"). The original driveshaft in a 1970 Charger with 318 and A904 transmission is 56.17" long, part number 2883792.
Both driveshafts are 3-1/4"in diameter.
Although the original specifications may still fit what is in the car, measuring to ensure the same is prudent.
Presto! Great, exactly what I was looking for! Thank you! So where does one find this information?
This specification information was taken from the 1970-1971 Chrysler Parts Catalog, publication numbers 81-690-1000 & 81-690-1002.
I have a printed copy, but a digital version is available on MyMopar.com
I am getting some vibration that I have not nailed down. I want to start with the basics. So I want to replace the u-joints on the drive shaft.
Does the transmission tail shaft on the 904 use a bearing? Would this be a good time to replace it as a potential suspect in the vibration?
Does anyone have the Spicer u-joint numbers for my drive shaft? Zerk or no zerk?
The A904 transmission uses a bushing in the extension housing, or tail shaft, for the slip yoke on the driveshaft. If the condition of the universal joints are unknown, they are more suspect than the bushing. If play of the slip yoke shaft in the bushing is not excessive, and the surface of the slippart is good, the bushing is good.
The original driveshaft, part number 2883791, in the Satellite has two 7260 universal joints. Dana/Spicer replacement universal joints for these are as follows:
5-1306X
5-1307X
5-3228X (grease fitting in cap)
5-1306-1X (grease fitting in cap)
5-789X (heavy duty non-drilled universal joint, without grease fitting)
Grease fittings, or zerk fittings, can be a weak spot in high torque, high traction applications, but for general street use work fine. Personal preference dictates beyond that. To maximize the joint strength, install with the zerk fitting under compression during shaft rotation.
Alternate universal joint brands and part numbers for the 7260 series, FYI:
BrandNumbersNotes
Chrysler4720822
4384514
4364400
3780250
3004900
2298908
1752624
858001
Later numbers supersede earlier numbers
MoparD207
D134
D134A
Detroit72625-3
72625-4 (with strap kit)
726251-2 (greasable, with strap kit)
726251-3 (greasable)
726252-2 (high temperature grease)
72625-2 (integrated straps)
Chrysler division
Precision315G
315 (non-greasable)
317 (grease fitting in the cap)
318 (315G with strap kit)
832M (angled grease fitting in the cross center)
Torque Manufacturing315G
315 (non-greasable)
Now Precision
Moog315G
245 (solid cross, non-greasable)
246 (heavy duty, greasable, fitting in cap)
832M (angled grease fitting in cross center)
Formerly Precision
Dana Spicer5-1306X
5-1307X
5-789X
5-789X is a heavy duty non-drilled universal joint, without grease fitting
TRW20030
20030P
20031 (20030 with strap kit)
Now Federal Mogul.
“P” denotes a performance or heavy-duty version.
Federal Mogul 20030P
McQuay-NorrisU1306
U0119
Parts Master315GPM
315PM
1019
Raybestos51306X
PTCPT266
MeritorCP1306X
CP13061X
CP72625-3
CP72625-4
CP726251-2
Formerly Rockwell
Sealed Power838-266
SKF1-6301
UJ315G
UJ246 Brute Force (greasable)
UJ246 is a heavy duty version
Carquest1-6301
Neapco1-6301
1-6300 (grease fitting in cap)
AMC8126636
3114708
Also Chrysler J8126636
GMB210-1306
211-1306
G5-1306X
Raybestos51306X
Alloy1019
41019
J72625-4
Borg Warner114-266
1142HD
1142HP
NAPA315G
Tru-Cross1306
Sosmetal62218
Wesco201255
D255
Amgauge/AEC266
RepublicCB-72625-4
Central229
Sierra Marine18-2104
Wow thank you so much for taking the time to respond in such detail! Really appreciate it!
