- 2:05 AM
- May 14, 2011
- On the Ridge, TN
You guys know the story already....
I've just recently replaced all the 11" drum brakes at all four corners,
using all US-Made hardware, wheel cylinders, hoses - and yes, even the shoes
(Porterfield).
At this point, the only parts left original are whatever Fred has for a distribution
block and the hard line headed back to the rears.
The master cylinder is the correct bolt-through-the-lid replacement and fairly new.
I had the issue with the left front hub being all beat to hell, so thanks to a fellow
FBBO member, a new one now resides there and looks/works just fine, along with
new bearings, seal, races, the whole she-bang.
Everything has gone over...and....over....and over yet again and more than once,
I thought I had it figured out.
Today's drive, however - the hard pull to the left once the brakes got some heat
in them returned, along with the accompanying hot wheel center when I reached
down to check it out.
At this point, I've about run out of things it could be - unless something funny is
happening with that distribution block or whatever it is??
Is there a check valve involved between the sides on the front brakes?
(Porterfield).
