FOUND drum/drum 69 manual brake master cylinder
dan juhasz
11:05 AM
Whiting NJ
Feedback: +23 / =0 / -0
Looking for an original rebuildable manual drum/drum 1969 master cylinder.
Same as a ‘68 manual drum? Or are you looking for a date code one….
Not looking for date, just looking for proper operation and correct cap. It seems the Chinese ones perhaps have a different bore size which affects brake feel/application
My Chinese replacement from Rockauto had the same bore. But your correct the cap and bolt are wrong.
Ok I have one that would need restored from a 68 I am parting.. Can check its condition afterwork..
I believe I have what you need I’ll send a pm with pictures
Here’s the one I have. Pm any interest.
Is it frozen our can you still pump the pedal
You can pump the pedal BUT brake line is rusted out so pedal goes to the floor... That said I can pull the cover to make sure it's not corroded inside if interested..
Sure if you don’t mind. It’s a good sign that it’s not frozen. How much do you need for it, I want it with the rod too.
I will try and take a better look at it tomorrow. Packing for Carlisle today. I just started parting this 68 last weekend..
