Early B to '66 and up 727 speedo cable
Dodge 330
4:56 PM
Wichita, KS
Thought I would post this here as I came across this and found a solution on a other forum.
A 67-69 Camaro cable is the perfect length and mates up to our small speedo head size and larger, later 727 sizing!
$35 later and speedo/odometer works perfectly!
Good to know that! I have an NOS speedo cable for my '66 that I have yet to install, but that Camaro cable info is great to know!
That was my post over on Moparts. Your welcome and glad it worked. It took me a long time to find the right part that fits. No "Mopar" shops sell anything that fits correctly.
http://board.moparts.org/ubbthreads...speedometer-cable-with-1966-or-later-727.html
Not sure if this has been posted before, but I could not find it on Moparts or anywhere else and had to figure this one out myself. If you happen to need a retrofit speedometer cable for an early 1962-1965 B-Body using 1966 and later 727 Torqueflite, I found a perfect part that fits. Hold on to your chairs, it is for a '67-'68 CAMARO!!!
The original speedometer cable for my 1964 Plymouth Savoy with the pushbutton 727 measures 68 1/2 inches. I found that the 1967-68 Camaro originally uses a 69 inch Speedometer Cable Assembly. I ordered one on eBay, and installed it yesterday. It fits perfect and fits the 727 and speedometer like a glove. FYI...I tried the local Napa, Autozone, Oreilly's, ect, also, and none had a cable even close to the right length, so back to the internet for parts. This might save you some time, try these links:
Part numbers on the speedometer cable is SC-72 and W-871.
http://www.ebay.com/itm/1967-1968-Camaro...p;vxp=mtr[/url]
http://www.rickscamaros.com/camaro-speed...-1967-1968.html
http://www.restorationperformance.com/servlet/the-158990/67-dsh-68-69"-Speedo-Cable/Detail
