Edelbrock 800 AVS2 Tuning
SlinktRR
2:08 AM
Dallas TX
I have run an Edelbrock AVS 800 (1812) for a few years now on an RB 499ci stroker. It dyno'd at 600bhp and 625 ft-lbs torque and runs really well with a ported holley street dominator and trick flow 240's, 18 initial 34 total timing. Cam is Comp XS290 solid, so 10" vacuum most of the time. My wife keeps complaining about the fuel smell. The AVS I have tends to run lean at idle, so I've been adjusting here and there to clear that up. Full throttle, idle performance, in gear it runs great just the lean stink. I bought the 800 for super cheap used years ago so I figured hey I'll buy the new AVS2 800 from summit, it should just bolt on and go.
I put it on and tried to set idle. It idled beautifully, 10" vacuum on the gauge at 1000 rpm. The old 1812 came stock with .113 jets, but I changed those to .104 when I first got it and tuned to 7052 metering rods which is how the 499 engine liked it. The new 1912 AVS2 comes with .104 main jets but stock calibration has 6552 rods and orange 5" springs. So I ran it like that and it idled smooth. Idle screws 2 turns out, like the old carb.
Then I put it into gear and it would die. Checked plugs, lean. I had to go 5 turns out on idle screws until it would idle in gear, which I have never had to do on an AVS. Also put in yellow 4" springs. Still rough in gear but wouldnt die. Around town it ran terrible so I used the edelbrock chart and started changing rods. Any change and the idle would go bad in gear. I had to do other things at home so I set back to stock drove back and parked it.
I'm going to go through the old AVS and clean it up, recondition it to put back on if I need to. In the meantime I'm going to call Edelbrock to see what ideas they have and also ask FBBO for some help. To sum up, only change was AVS to AVS2. Jet change? I may need to deviate a lot from the edelbrock tuning guide for jetting. The good news is the lean stink is gone, but it runs like *** so not a good trade off. The 5 turns out idle screws also threw me for a loop which makes me think there is something wrong in the idle circuit of the new carb.
I have the 1913 carb. Only Diff is e choke I think.
Engine- 451 with Hughes SEH3236bl-10, changed to 6557 rods and left orange springs in. Stock jets. No problems here. 3550’ elevation....
Curious to see what you learn. I have a new 800 AVS2 onmy 512 stroker build. Hasn't been started yet. ruffcut
I pulled the top off my brand new 800 AVS 2 right out of the box a few summers ago
Just to verify float level and drop and check things over
Glad I did - I don’t know if it would have even ran , the primary float was barely letting the needle off the seat
And one of the float baffles was not installed in the slots or grooves
I said , wonderful - Anyways this was replacing a pretty damn near perfect running 1970 Carter AVS 750cfm that I rebuilt and converted over to Edelbrock Jets and Needles
Back to the Eddy 800 AVS 2
Have it set up as 5/16" float levels instead of the recommended 7/16" using a drill bit underneath the middle of both floats
1" float drop on both
I run the pink springs , as I have around 13" vacuum at idle (Comp XE275 HL)
Played with primary Jets down to .101 at one point , but back to factory .104 P .104 S
.068X.052 Needles
Around 1.5 turns out on each mixture screw for max vacuum
I run the exact same timing as you do
383/432 Stroker - E Street 75cc Heads
Idles in gear around 600/700 RPMs all day long , instant throttle response off idle
Can destroy the 275/60 Rear Tires off idle from Green Bay to Chicago if I wanted
LOL
Best street carb I have ever bolted up
I would imagine you guys running 500 C I D Strokers would or might have to go richer
If yours is dying in gear , needles and jets won’t fix that , and five turns out on screws
Something else is going wrong
I forgot to check the floats, for sure. And that has happened to me before with an AVS. Check floats, air bleeds and blowing out the idle circuit is my plan for now until edelbrock calls me back.
Update: went through the entire carb but no dice. Something very wrong with the idle circuit that I could not clear up. Lean everywhere. RMA back to edelbrock, summit gave me full refund.
While messing with the 1912 I rebuilt the 1812 completely with a carb dip in dichloromethane and new gaskets, now the bastard runs like new. Lot of varnish in the idle passages and air bleeds. 12" vacuum at 800rpm and no lean stink. The wife is fine riding in the car again hallelujah. The 1912 annular boosters fit the 1812, too bad edelbrock doesn't sell these separately!
Glad to hear you got the 1812 running. I recently swapped my FiTech FI for the 800 AVS2. I'm absolutely amazed at the idle quality and part throttle response. The motor runs better than on the FI. Something must've been wrong in your carb.
