FOR SALE Edelbrock Pro-Flo 4 EFI system for 426 Hemi
PsyOps
5:32 PM
Pacific NW
Feedback: +3 / =0 / -0
New in the box, Edelbrock Pro-Flo 4 EFI system for 426 Hemi based engines (35670). Fits OEM style heads. Supports up to 825 hp. System includes:
* Engine Control Unit with faster processor and upgraded Bluetooth chip in a thinner waterproof design
* 1000 cfm throttle bodies, fuel rails, and 55 lb injectors
* Fully assembled OEM high-quality wiring harness with pre-terminated connectors and labeled connection for a simplified installation
* E-Tuner application for setup and engine monitoring
* Wideband oxygen sensor
* Dual-sync Distributor
* Gaskets and hardware
* Installation instructions
* Ready to run out of the box with pre-loaded calibrations
* Self-learning technology--no tuning experience or laptop tuning required
* Ignition control--adjust ignition curve with the E-Tuner 4 App for optimal performance and mpg
* Offered with multiple fuel injector choices
* Now boost compatible up to 15 psi by switching to a 2-bar MAP sensor and downloading the new firmware update from Edelbrock for free! It is recommended to regularly check for firmware updates even if not utilizing boost control.
* Systems automatically compensate for altitude and weather changes
* E-Tuner 4 app with Bluetooth connectivity between ECU and Android phone or tablet. Includes multiple dash display configurations for monitoring engine vitals and performance; multiple control functions including two adjustable cooling fan outputs, idle speed, AFR set points, acceleration fuel tuning, ignition control, cold start fuel, and cranking fuel.
This is the most complete multiport efi system you can buy for the money. Summit gets $3239.95 for this; buy mine for $2699 and I'll split shipping with you from 99201. Box is 30 x25 x11 & 50 lbs - check shipping at Pirateship.com. Reason for selling: I'm opting to go old school with a cross ram for the '68 Dart. PayPal F&F (add % for Goods/Services) or postal money orders please.
For interested parties, I'll throw in a new set of Mancini black HEI plug wires for $99.
