Educate me on 4 Speeds!
drobertson
5:25 AM
Wyoming
Hey, David here. Whilst restoring my 73 Charger, I am converting it to a 4 speed. Where does the ball stud bracket need to be welded on the frame rail ?
Question #2 how can I identify the proper 4 speed for my Charger? Like the differences between the years. I have an uncle/cousin that has a whole bunch of mopar stuff, and a few 4 speeds. Which ones should I look for that'll be correct for my car? I'm not worried about numbers matching. I plan on sending the 4 speed I buy to brewers to have it rebuilt w/ an overdrive gear set.
Question #3 Is a clutch pedal/brake pedal assy a bolt in deal on an auto-born car? Do I need to drill a hole in the firewall for the clutch rod to poke through?
Thanks all, -David
Start with the manual..........
http://www.mymopar.com/index.php?pid=109
Some 4spd info here may help............
http://www.bigblockdart.com/techpages/4sptech.shtml
There may (or may not) be slots in the frame rail for the correct bracket to fit in. Otherwise I believe you want the torque shaft (z-bar, bell crank) straight across in any view. Engine and trans assembly in the correct location or the clutch rod may not align.
The clutch rod runs through a vertical elongated hole that may just be plugged or need to be cut out. My '68 was plugged. It was also a bolt in/on for the pedal.
