How long can you hang on to the battery?
Mike
Mike
When I worked for a company upfitting first responder vehicles, the "lead electrician" was a licensed electrician (commercial-residential) and because of that license he was designated the lead electrician.Great idea... thanks Mike. I have a solid grasp of residential and machine electrical, but admittedly am a bit weak when it comes to automotive electrical. For a guy whose been a professional machine electrician for over 35 years, it's kind of embarrassing really.
Is that one of them 12 volt hand warmers?
It's a heavy duty joy buzzer.Is that one of them 12 volt hand warmers?
One of my problems is that I'm shade blind. Not quite color blind but bad enough. Yeah, I can trace out circuits but have to mark them so I can keep track....it just takes longer and gets frustrating.I will admit I had automotive electrical training at college and systems were much simpler back then, but the basic principles haven't changed and they are simple. We have a LOT of electrical issues on this site and too many are declaring "electrical ignorance". Perhaps a sticky of electrical circuitry could be included here with a list of educational sources incorporated? Old dogs CAN learn new tricks!
Mike
What chaps my butt is that I didn't know I was shade blind until several years later after taking the dang test for the military.....Ishihara test....color dots. I remember taking it when I was considering joining the AF right after high school and wanted to get into the electronics field but no one said a thing about me not passing that test. The field was never open for me and probably because of not passing it and imo, they kept it quiet.As long as we can all tell the difference between the pink and the brown.![]()
I had an apprentice with me a long time ago who was colour blind. He was always getting mixed up between the green and the red....a real issue when fitting off power sockets in a house or factory. I was always have to check his work, and of course we picked up all those with testing the circuits.What chaps my butt is that I didn't know I was shade blind until several years later after taking the dang test for the military.....Ishihara test....color dots. I remember taking it when I was considering joining the AF right after high school and wanted to get into the electronics field but no one said a thing about me not passing that test. The field was never open for me and probably because of not passing it and imo, they kept it quiet.
Several years later working at a local steel mill and being laid off for over a month, I get call that an overhead crane operator retired and I was next in line. Sure....when do I start. Right away! Ok. Was in the crane for months when I was told I needed an eye test and that's when I found out. Supervisor went to bat for me saying that I was one of the best crane operators he's ever had. Dang thing was easy imo and the only colors I needed to see was dark Red, dark Blue, and bright Yellow and those are easy. Everything else was raw steel gray!
Took an electronics correspondence course while in the military and didn't see all the colors but I did learn something but geez, that was a long time ago. And old faded wiring gives me the most trouble. Dirty lenses on traffic lights were a problem too but since the advent of LED's, that's not a problem anymore but had to learn green on the bottom for vertical (no more of those around here) and green on the right for horizontal....before LEDs and now, I don't have to worry about that. A local crooked town had it backwards and made lots of money off of that until someone sued the pants off the city and won. It got changed right away. Today, a traffic light isn't even there.
In the US for home wiring it'sI had an apprentice with me a long time ago who was colour blind. He was always getting mixed up between the green and the red....a real issue when fitting off power sockets in a house or factory. I was always have to check his work, and of course we picked up all those with testing the circuits.
I asked him one day about the traffic light thing...he said that is easy because red is top, and green is the bottom.
True here - nearly everyone is on-board here with that. All my controls are 24VDC..... so much easier, and you can't be shocked bad by that either.But increasingly most instrumentation in a factory is either 24Vdc or some networked device scheme.
Unless you're from anywhere BUT the US where BROWN is earth, not GREEN unless it's made, specifically, for US consumption.In the US for home wiring it's
Blk (or occasionally Red) for 120 VAC L1,
Wht - Neutral
Grn - Ground (or base Copper wire)
Green is always ground, in an industrial setting Black is usually right from a lighting panel while Red is usually a control circuit either from a fuse or breaker or an output. But increasingly most instrumentation in a factory is either 24Vdc or some networked device scheme.
So most everything is in Black and White. (And everyone says we're dumb)
House wiring is a snap in most cases. I did a study on it before wiring my 1500 sq ft shop with 3 220 drops, wall outlets and ceiling outlets so I could plug in my lights how I wanted. Helped a buddy wire his new house and back then he knew more about it than I did but these days I'm not sure if he knew more than me or not lolIn the US for home wiring it's
Wht - Neutral
Sounds like your talking about appliance cord?Unless you're from anywhere BUT the US where BROWN is earth, not GREEN unless it's made, specifically, for US consumption.
Nope. 50hz residential, appliance, etc. wiring. Saw a lot of it in Australia.Sounds like your talking about appliance cord?
