steve from staten island
- 5:29 AM
- Sep 24, 2012
- staten island,ny
The wire that powers the positive side of the coil is disconnected from the coil itself. There is a slight ground in that wire. Ignition off and battery disconnected there should be no ground even slightly at that wire. Something is shorted and its either the voltage reg or the ignition switch.Over charge will not burn wiring, only the battery cannot stand much more then 15V.
The voltage regulator only controls voltage, thats it.
I am quite sure the slight ground you are measuring is because of the coil itself.
A ground against the positive side of the coil will create fireworks.
You said measuring at the battery you confirmed it is not charging, so what about at the alternator itself?
Is that showing 14+ volts? If it does there is a massive resistance, probably in the bulkhead connection area as there are signs of overheating.
This in effect causes a voltage drop and could be the reason why there is low voltage at the battery.
I disagree about a overcharge causing high amperage and melting the fusible wire. My complaint is the wire should have melted but not melted the bulkhead connection...As I said even the output wire from the alternator at the bulk head connections show overheating.
That male and female spade connections at the firewall can not take high draw....
I still want to know if the terminal on the voltage reg, the terminal opposite the field connection. Should there be a ground from that to the body of the regulator itself.... I say NO.... Im looking now for a spare reg to test it and see for myself. Will let you know what I find and thanks for the help
