Electrical issues
73Mopar
New Member
11:51 PM
Sask
Hello. I'm looking for help concerning my 1973 Charger Rallye. I have no power whatsoever. Any ideas? Suggestions?
Do you have a circuit powered test light? If so work your way from the battery to the ignition switch, checking for power at each connector.
Mike
Make sure your terminal posts are clean. Take off terminals and clean posts and terminals. Then check to see that you have 12 volts at the starter relay. I know this is basic but it happened to me with the posts being dirty and I almost got stuck at a gas station. No tools in the car, I had to beg the mechanic for a wrench to tackle the posts. Car started fine that AM but refused to start after getting gas. Now I have enough tools in the car to rebuild the engine.
