Electronic Precautions While Welding
Moparfiend
4:21 PM
HOT
So I am going to be doing some mig welding on the car like real soon. What precautions should I take such that I don’t damage my electronics. I am running an MSD Billet dizzy with a MSD 6AL box. Factory AM radio boogie alternator and um I think thats the whole entirety of electronic stuff.......
its more of an issue on modern cars......but it doesnt hurt to disconnect the battery.........I would remove the msd box, only takes a minute...... keep welder ground close to where you are welding
Take the MSD box out completely. I ruined the heck out of a -7 thinking I could just unplug it.
Ok will remove it physically from the car. Better safe than sorry!!! Thanks for sharing your experience.
when I had a collision shop, I had an employee fry every module in a chevy cobalt........ he cut off mashed piece of metal with a plasma cutter and that was that
I think that was the day I decided to pack it up and come home to work on old cars by myself
MSD used to fix them for free...but those days are long gone. Mine's a dinosaur, but they did repair it, albeit at a cost, but still worth it and it works great now. The inside looked like a bomb went off in it after the welding incident.
Welding with dc usually doesnt doesnt damage electronics. I've done a lot of welding with dc and never a problem. But, good idea as safety precautions unhook the battery, put your ground close to where your welding. Now ac welding is a different story....computers will forget who they are and have to be reprogrammed or replaced.
MSD repairs their boxes? Even old ones like my MSD 6 from '95?
Yes, they do. Mine was really old... long before they were bought out, and was made when they were still in a little shop in TX (el paso?)
You send it in, and they'll quote the repair. There is a maximum cost, and it's still a deal if it goes that high. You will get the oppoutunuty to yea or nay before they start repairs.
Call the phone number on this site, and they'll get you started.
https://www.holley.com/support/support_request/
I believe it was "Bitchin Rides" I was watching, he has that custom door handle their known for, and a new guy was welding on the quarter panel with the ground clamp on the bare metal where the door handle was just installed. That would arc through the door hinges and who knows what else.
It's what you have to think about when welding anything. What's the path of least resistance? Welding on any vehicle there's bushings, ball joints, bearings, and most of all the electronics. Clamp off right at or as close to the weld.
Welding and plasma cutting creates high frequency waves also and that is what can cause damage to the newer electronics. It can cause problems with a person with a pace maker and or defibrillator implant also.
Welding and plasma cutting creates high frequency waves also and that is what can damage to the newer electronics. It can cause problems with a person with a pace maker and or defibrillator implant also.
Both my pace maker AND defibrillator were removed but not for welding purposes lol
Make sure the welder ground clamp is connected close to where you are welding, and on the same metal part. Grounding through parts like bearings and hinges can damage them. Connecting the ground that is not near the part, could be the ground is isolated from the metal trying to be welded, like grounding to a tail pipe that may be isolated from the body. Or even forgetting to ground the welder, can really cause problems when the welder tries to complete the electrical circuit (higher welding voltages, unknown ground paths?)
Thanks for that. My ancient MSD 6 is still kicking, I just wanted an alternative to the new digital boxes because I heard they're unreliable...
Yes ground as close to well as possible but the voltage is lower and amperage is higher just saying :welcome:
Depends if the welder is constant current or constant voltage. Constant current will ramp voltage much higher trying to establish an arc. Also, because voltage is I * R, High resistance in the ground connection can create higher voltages. Sometimes when you goto weld with the work not grounded, you will get a shock as the current can flow through your body too.
