Empty hole
green 66
2:37 AM
Thomasville Nc
1974 727B where tailshaft housing bolts onto tranny,there is an empty threaded hole,almost looks like a barrel washer that moves in and out. What is it for?(see pics) 787BC5E8-76B0-4491-8624-34C58DA114BD.jpeg
That is the pin for the rear servo. It has 2 O-rings to prevent leaks, and is retained by the tailshaft housing...
Any pics on how it’s supposed to look? Trans seems to work ok just chasing some leaks- thanks
What ? What? Ohhhh. Sorry. By the title of the thread, I thought you were looking in my ear.
If that pin leaks it can be sealed. Press it in as until it bottoms. Clean with brakleen. Use a putty knife to fill the cavity with a good quality RTV.
I chased that leak for years not realizing what I know now
How many different style pan gaskets got replaced numerous times
Even a new pan
Fix it the right way
My o rings literally where rock hard when I removed that shaft - A little work , valve body , tail shaft housing
Anyways
Really appreciate a simple cork pan gasket and zero rtv when all the leaks above are fixed right
