- 5:33 PM
- Jan 14, 2009
- Shoreline, Washington
Both ends are slotted to accommodate production variances. Again, they not stout enough to control serious movement. The center stud, found all b-bodies starting in ’72, does have a small reinforcement plate behind the center upper cowl panel, but still the upper cowl panel is thin and provides little structural support. No way these would control anything but sheet metal, upper fenders, rear hood & hinge, lateral movement.
As for what ’72 engine applications received them from the factory, documentation is scarce. I only saw them on big blocks back in the day at the dealers, the added weight caused excessive sheet metal movement is my guess. I’ve heard some ’72 340 owners claim they had them originally. Fairly easy to add to any ’72 however. And easy to spot on original paint engine compartments if they had ever been installed, undisturbed paint on the center stud or fender locations.
