engine tube . Where does this belong?
plysase
3:37 AM
Bavaria
hello .
i found a tube in the engine compartment.
It comes from the valve cover.
the tube is very thick.
where must i put on? on the air cleaner housing , or what??
i am perplexed.
thank you .
is this for vacuum, perhaps?
C'mon man this one is just ripe for some picking on man gotta hold back lol
PCV to Air cleaner?
The PCV( Positive Crankcase Ventilation valve) the valve that is in your valve cover usually has a hose that goes to the air cleaner or carburator and is larger than vaccum hoses but smaller than heater hoses.
Hope that helps
hey, there is only one hose that comes from the pcv!! i make a picture!
hello .
i am perplexed.
thank you .
Please post a picture. It makes it mjuch easier to help.
This it?
thanks moparlar,
i will fix it tomorrow!
could it be possible , to have effect on engine running.???
It shouldn't affect the engine running it is the inlet air for the PCV system
thanks. i still will fix it. i`m a perfectionist.
the forum was able to help me twice.
