mopar 3 B
- 10:25 PM
- Aug 25, 2014
- Kingsville, MO
H2O last know was hydrogen and oxygen. Even with no coolant in the system there is oxygen. Whens this stuff going to cure?I is my suggestion that AFTER the coolant is drained below the level of the heads, and after removing the stud, to tap the hole to clean it up and remove the crud. Purchase new studs from a Mopar source for the correct location. NOTE THAT THERE 2 DIFFERENT THREAD SIZES...THE ONE IN THE HEAD IS DIFFERENT THAN THE EXTERNAL PART OF THE STUD (the part where the barrel nut screws over). When ready to assemble, I always use a LOCTITE product....a thread cleaning material followed by (my choice is Red hydraulic sealant or Red thread lock...all applied sparingly per instructions and installed with stud installer and tightened to 20 ft pounds torque. Loctite products are anaerobic sealants...they cure WITHOUT AIR. LOCTITE material is avaliable at most autopsies houses...NAPA is a good starting point. DO NOT USE TEFLON TAPE OR PIPE JOINT COMPOUNDS . If you use the LOCTITE PRODUCTS THERE WILL BE NO LEAKS BUT FOLLOW THEIR INSTRUCTIONS.....
But this is just my opinion.....I'm sure that there will disagreementstill.
Cheers
RJ RENTON
