tendy30
Hey Guys,
I have a 1969 Charger r/t. I started a project this weekend and certainly am in way over my head. I pulled apart the dash to see why the fuel, oil, and temp gauges don't work. The alternator works fine as it's on as separate feed.
As I pulled the instrument cluster out of the dash, I did notice whoever restored the car did some sodering in various places. I used a tester to make sure the 12 volt feed has power and it does. I then tested the 4 or 5 little prongs that are attached to the circuit board and they all have power however, it's not consistent. It's more of a pulsating light on the tesert.. on and off every half second..similar to a turn signal. I also tested along the circuit board and it's producing the same turn signal like flashes. Anyways, I then took the whole cluster out and two of the prongs have been sodered but very stable. I'm out of solutions and started to look at a whole new dash cluster, HOLY SH*T $1500 later. Not something I want to purchase this year and even if I did unsure if that will solve the problem.
I highly doubt all 3 gauges are dead but I could be wrong.
Any help would be of great assistance,
Al
Al
