Dibbons
- 2:24 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
After replacing the 318 with the 340 (and retaining the 904) in the '72 Satellite Sebring Plus, I purchased carb throttle bracket/linkage for the '72 340 in a BBody. Would work just find (photo #1) However, the one piece kick down 904 transmission rod is now about 2 1/2 inches too far away (about 2 inches horizontally and about another 1/2 inch because it is also a little higher so I had to measure on a diagonal) (photo #2).
I'm not sure if it makes a difference which end to lengthen, either the kick down rod itself or the mini-bracket with the small bolt it attaches to). Personally, I would rather not fool around with the kick down rod which already is slotted and connected to the transmission under the vehicle. In other words, my first try most likely will be to extend the little swivel thing with the bolt either 2 1/2 inches or maybe even 3 inches.
