- 3:48 PM
- Jul 9, 2019
- Modesto California
Just saw this & thought it was pretty slick...
I used those when I replaced the front stub on Jigsaw.There are actual correct spot-weld drill bits available that make a countersunk hole on the first panel, and a much smaller centre-drill type hole on the back - typically 1/8"
Just enough to get release between the panels.
It does look like a good solution in the right situation. It is certainly fast!Since everyone is using AMD metal these days it might not be as relevant, but back when I was grabbing clean used panels off parts cars & wrecking yard cars I drilled lots of spot welds... If no one saves old metal anymore fine, it's not a useful technique... Forget I brought it up...
And I see that as the point... Back in the 90's I spent countless hours drilling spot welds to remove panels from Pick-n-Pull yards... They didn't allow gas powered tools or generators or torches... So battery powered drills & later battery powered sawzalls were the best tools... Though I did remove a few panels with an axe & a hammer... Looks like a scary technique.. But very fast & effective...It does look like a good solution in the right situation. It is certainly fast!
Mike
