Fender top blinkers
MMorgan
5:41 PM
washington state
Maybe stupid question of the day. On my 68 Coronet fender top turn signal, when you remove the top screw and pull frame up and pull the post out of the fender hole, there is a sleeve that either works as an insulator or as a conduit for ground? It is mostly destroyed. I’ve cleaned what’s left up, and I know it’s the cause of my intermittent function of the light. What’s it’s purpose? Can you find them anywhere? Thanks..
Try Kruzin Moons they have replacements just not sure if it’s your style without looking
Pictures of said sleeve?
The ground should be provided by the bracket sandwiched between the nuts and the fender.
