Fiberglass hood 4 pin install
young99
11:15 AM
Alabama
I picked up a fiberglass hood and trying to decide the best way to line it up to drill the pins. This hood does not have the ability to attach a hinge. I am guessing that Ill need to put in my brackets and really low hood pins or bolts to get a drill spot?
Figure out where your hood pins will be mounted. Then measure their postion. Along the cowl you measure how far in from the fender, and how far up from the cowl on each side. In the front you measure how far in from the fender again, and how far back from the grille. Once you have those measurements place the hood on and adjust it so your gaps are even. Then, using the measurements in step 1, mark the spots on the hood where the pins will go through. Then gets to drillin'
