filler neck
74charger07ram
8:01 AM
Weatherford Texas
On a 74 Charger does the filler neck go up to the detent and gasket or does the detent go throught the gasket? Thanks
Hi, I have a 1973 Charger and I followed the service manual. It said after installing the tank, you would lubricant the grommet with a petroleum jelly then side the filler tube into the tank, and secure tube with screw, tighten securely. Where ever the tube ends up is the only place it will be.
Good luck
Azmoparboy
