Firewall\Grommet Suggestions for triple gauge and tach
67satellite
7:35 AM
Illinois
I am looking for suggestions on running triple gauges and tach through the firewall. Where? How? Grommet to use?
Thanks!
There's a body plug to the left of where your column goes through the firewall. Oblonged, vertically orientated. May work for your for routing. Tach wire to negative on coil and a positive lead, temp sensor up by water pump or use a block drain, oil off back, top of block....Just the route I would/have gone
Good luck.
The body plug by the column is the ticket. Since it was painted over, I didn't see it as a plug. Thanks.
