DAVID SWEET
New Member
Hoping someone with experience with the FiTech system can help. I've been in contact with the Fitech support people but progress is painfully slow. I've spent the last 2 weeks with little success.
Fitech Go EFI 4 600 HP system.
Timing Control via Fitech. MSD Pro billet with an MSD 6A ignition.
440 Mopar, Cam is a Comp Cam 21-225-4, 110 lobe separation, 240 lift at .050 Intake, 246 lift at .050 exhaust, total lift is .507 Intake and .51 Exhaust.
Compression reported at about 10.5:1
The engine has run with an Edelbrock carb and Mopar electronic ignition. No internal work has been done since it last ran.
Base timing is set at 8 BTDC with an idle setting on the controller of 18 BTDC.
I've checked and verified voltage to the Fitech and MSD units during cranking and run at +12V.
Fitech controller shows that I'm getting a tach signal and I've had the engine running twice but only for short periods. Lots of cranking and controller changes in between runs.
I've tried cam settings 2 and 3 with no noticeable changes.
The engine acts as if it wants to start, noticeable cylinder firing but won't catch and run. Partial throttle seems best but only early on in the cranking process. If it cranks for a while the firing drops off regardless of throttle location.
I've increased the cranking fuel values at 65F and 170F at the advice of the Fitech reps. It was during the changing of these values, +10 each time that I got the car to run for about 1 to 2 minutes. It then died and it hasn't started again.
I've slowly increased the crank fuel and afterstart fuel settings at 65F and 170F until they were maxed out with no noticeable changes in firing.
The unit did post P0505 IAC fault codes on 3 occasions now and Bryce at Fitech is supposed to be sending me a new IAC. Hoping that's it but wanted to see if anyone out there had any other ideas or experience.
Thanks
Thanks
