jc69rt
New Member
I need some help PLEASE! I have all new wiring harnesses including the dash harness from Year One on my 69 Charger. I have upgraded to the later square back 78 amp alternator with electronic regulator. My problem is the lights all flicker dim to bright especially at idle, the ammeter also fluctuates a lot, up to 40 amp briefly with lights, stereo and maybe brake lights on, while at cruising speed it is much more steady. Good grounds and connections, battery charges just fine. Are these just characteristics of these old systems or what? I'm considering the Denso upgrade that Mancini and 440 source sell, thinking it is an alternator or regulator problem.I'm a leery of the cheap looking bolt on regulator Power Master uses on their one wire units. I'm not necessarily wanting to go to a one wire alternator, but if that's the fix, I'm not against it either. I've read so many things about cheap rebuilt alternators and Chinese made regulators, I'm kind of at a loss. I have tried different alternators and changed the regulator to no avail; that being said, I'm afraid its pointing to a wiring problem somewhere. Your help and 2-cents worth are appreciated and I'll report my findings once I get it figured out, I'm sure I'm not the only one with this issue, Thanks!
