mmomike
- 9:40 AM
- Aug 1, 2013
- Pahrump, NV 60mi outside of Vegas
Would you know if there is a min thickness on the flywheel for a 69 Roadrunner?
There is no minimum. If you cannot get enough adjustment out of your linkage, you can get shims that go between the crank flange and the flywheel.
There has to be some kind of design criteria. It may very well be that you run out of adjustment, but a hell of a way to find out after you have everything back together.
