Geoff 2
I am working on a #9333 TQ which was used on Australian 302 Ferds. The air valve dashpot vac line plugs into the rear of the carb base, as per normal for the TQ. However, instead of just a steel tube pressed into the body, it is a brass ferrule with a tiny hole; didn't measure it but looks to be 012-015".
The sec jets are only 098". I am assuming this tiny orifice is designed to slow the dashpot release & work with the lean jet size.
Do any of the US models have this brass ferrule arrangement? Thanks.
