- 1:15 PM
- Jul 17, 2008
- South Jersey USA
I just removed a "solid" floor because of what hides inside the frame rails
The front spring hangers are bolt on and not a problem. The big difference is the rear spring mount. AMD sells both a Dodge and Plymouth version for B-bodies and is welded in. Remember why back when I bought complete Plymouth rear frame rails from you for my 69 Charger? That is when I learned all about this. Had to replace the rear spring mounts after it was welded in, blasted, and epoxy primed. At least I found out before final paint. Floor pans, frame rails, and springs are the same between Dodge and Plymouth 68-70 B-bodies, except for a few holes like Mark mentioned.
.....Shock cross members are the same.....
