SOLD Fresh rebuilt 360la
Moparmatt72
8:43 PM
Nampa, Idaho
Feedback: +1 / =0 / -0
Located: Riverside CA
Price $2000
72 block 360, has been 0.060 over, actually has good thickness still, was pulled out of my dad's ram dually. 10.1 comp, swirl port heads, ports were smoothed, performer intake, milodonwater pump, will have new brass freeze plugs installed, doing it tomorrow, mopar purple cam, lost specs was just a cheater cam. Steel crank, has a windage tray, Ly rods with KB pistons hyper, balancer and flex plate included since they were all balanced togrther., new police rubber elbow hose, mopar distributor, , will put new cap and rotor, Clevite bearings(main, rods), seal power moly top piston rings, king cam bearings, felpro gasket set. Has a intake oil splash shield, also instead of press in plugs, tapped the front oil passages and put a plug in. Anymore infoplease IM
20160715_181708.jpg 20160715_181655.jpg 20160714_222557.jpg 20160714_202209.jpg 20160612_133702.jpg 20160612_133654.jpg 20160714_222535.jpg 20160521_132035.jpg
Engine as you get when bought. Finished the freeze plugs install, champion RN503BC plugs, all stainless steel 3040 bolts (intake,w/p,crank pulley, w/p pulley,thermostat housing,valve cover, oil pan,coil,dist hold down, front cover)
