Front brakes
KRYLONKILLER
7:05 PM
PHILLY PA
Does anyone know if there is a company that makes a direct bolt on brake system that will allow me to use my drum spindles for 65 coronet
I used the setup from SSBC on my '65 Coronet with stock drum spindles. Work great.
I had manual drums on my 63,SSBC conversion was smooth with EVERYTHING in the kit right down to the cotter pins.I have a master off a 66/67 manual master.Stops my 3800 lb brick from over 130 MPH in the 1/4 without panic:blob1:
I have manual brakes. the orig master works fine, I put a dual from a later model but it works just the same as the orig, both 1" bore for manual brakes.
