Bruzilla
I'm looking for some information about front wheel bearings. The outer bearing on the driver's side wheel failed and I tried to replace it but ran into a problem.
When I replaced the wheel studs, I found there were apparently two types of rotors put on 74 road runners, identified as Kelsey-Hayes and Motor-Wheel. Based on the studs I pulled from it, we identified my rotors as Motor-Wheel units.
I got a set of inner and outer bearings at Autozone, but the inner bearings were way too big and it looked like the outer bearings were a little too big, so I'm guessing I got bearings for the Kelsey-Hayes rotors?
So I was wondering if anyone else has had this issue, and are there in fact two different sizes of wheel bearings, and how can I identify the correct set?
