Fuel Filter gone?
You can find somewhere to buy it by the foot ($20-$25 usually gets you about 25ft), straighten it, then try and put the multiple factory bends in it.
Or, you can get a pre-bent replacement. They come with all the bends already in the line. EOM steel $55-$65, Stainless steel about $99. It will come with one or two 'marked' U-bends in it to get it in a shorter box and directions on how to remove the bends. Then you simply clip it in, replacing the old one. Below is an example of a pre-bent line.
http://inlinetube.com/Preformed Lines/Web Line Listings/DB-CAT-04.htm
Good luck either way.
The rubber line between the pump and carb is pretty short. Should I just extend/re-route the rubber line quite a bit more to fit the filter?
