Charger Ted
I am beginning to tackle the vapor lock problem on my 66 Charger, 2bl, 318, automatic. In looking at some of the options, mostly I plan to bypass and eventually block off the mechanical fuel pump and install an electronic fuel pump at the tank and route the line away from running up along the block. My questions are, 1) what fuel pressure is normal with mechanical pump, 2) Is an adjustable pressure regulator a good idea and if so what pressure to set it and recommendations on brand? 3) Recommendations on electronic pumps. I have a cheap $20 one at the tank at present but would not want to completely rely on it. TIA
Charger Ted
Charger Ted
