dsd1967
I'm looking to buy a fuel pump for my 512, and would welcome recommendations from anyone running this size engine. Will a holley or carter mechanical fuel pump provide the flow that I need and will I need a fuel pressure regulator. A few details on the motor
- 512 cu in
- Hughes Solid Flat Tappet Cam - HTL5660BS3 Lift: .579" Intake, .587" Exhaust, 108 degree LSA, duration at .050": 256 I, 260 E
- Head flow at .550" = 318 I, 256 E.....@ .600" = 322 I, 260 E (Mopar stage VI heads)
- Compression Ratio - 10.6:1
- Edelbrock Victor Intake
- QFT 850 carb
- Dougs D452 headers and full 3" exhaust
With the combination, I feel that I will be above the 550 HP range, and want to size the fuel delivery system to meet the needs.
I'm reading on the Mancini website that the Edelbrock RPM fuel pumps will support 600 Hp and does not require a regulator (6psi max pressure)....the Carter Super Strip will flow 120gph up to 9.5 psi, and the Holley will require a regulator on pumps that flow 130gph.
I'm new to this HP range and don't want to short myself if the Edelbrock uint won't work. If I have to step up to a pump/regulator, what regulator will be recommended.
Let me know what you are running and the likes and dislikes. I stayed with the 850 CFM because I want the street driveability and throttle response. My motor builder said that unless I want all out performance, I wouldn't notice the difference if I went larger Carb.
Thanks in advance for feedback/recommendations
- 512 cu in
- QFT 850 carb
