Fuel System Leaks: 1966 Coronet - Pics Included
watermelon
5:38 AM
main street, usa
Hi All,
A while back I found out I had a leaky gas tank at the point where the inner-filler tube and gas tank meet. Also, it appeared as if the inner-filler tube backed out of the tank itself. The pic below shows the leaking areas in yellow:
I used that as an opportunity to clean out the entire fuel system.
In restoring eveything I replaced the leaky grommet with a new one. However, the leak persisted at the same spot.
Another pic:
At this point I was comtemplating the following solution (let me know if this makes sense):
1: Weld on a 90 degree (or other angle) piece of steel tubing to the point at where the original inner-filler tube would have been inserted into the tank
2: have that new welded-on piece extend a few inches toward the inner-filler tube & also cut the original inner-filler tube a few inches at the tank end
3: span the gap between the newly welded-on piece and shorted inner-filler tube with rubber hose
I mainly want to get rid of the grommet (i've had the luck of leaks at that point).
Other pics for reference:
Also, this is the gas cap that is currently on the car:
Can I use a newer sytle gas cap? I have heard of "vented" gas caps. What do you recommend?
I think my inner-filler tube backed out of the tank because of pressure in the tank. Is that possible?
That is why I think I need a new gas cap too.
Let me know what you think.
Thanks,
watermelon
update
Well I went ahead and modified my fuel tank a little.
The welds look ugly but the tank passed the leak test. I just did a test fit. I'll probably weld a bead around the edge of that exhaust piece.
This was a prototype. I'll probably be ordering a new tank and do a cleaner job the next time around.
See pics below:
[/IMG]
I may or may not use the original inner-filler tube. I found some pieces that will probably do the job.
watermelon
