Fuel Tank Vent Question?
dodge68charger
8:41 PM
Washington
I Had My 69 Road Runner Mini Tubbed And The Holes Where The Grommets For The Vent Line Go Were Filled In.
The Stock Style Vent Line That Runs In The Trunk Wont Work Cus The Tubs Are Really Wide Even If I Wanted To Use It.
Is There Any Other Way I Could Vent The Tank?
Just drill 2 holes in the the trunk floor by the inner wheel tub/ trunk hinge area. Make them the size of the grommets. Bend a tube from the tanks venting port up into the trunk. Make a nice loop in it and exit it out the other.
You don't need much to vent a tank. I use a
power brake booster vacuum line charcoal
filter and a marine/boat bug screen. Simple
and cheap. No gas fumes in the garage.
(The black filter/short hose section/billet
bug screen). The bug screen has a check
valve to prevent fuel flow if you're upside down.
