Now that I'm getting back on dad's truck and doing the bodywork it's high priority to get the compressor out of the work area! Pretty sure it's going upstairs but when I do I have no choice but to start plumbing the lines. I know I absolutely do not want any black pipes but what to use
. I've got a friend who plumbed his in copper which is a viable option but I'm really liking the looks of these kits you can buy nearly anywhere that use what looks like Pex tubing and push on fittings. The ultimate option would be the aluminum kits I can get through our air system supplier at work but ?????? It's basically thin wall tubing, you borrow the installation kit which consist of a jig for holesawing the holes true then you simply install clamp on fittings, really nice setup.
Anybody use the Pex kits? Any other suggestions?
2 other concerns are the temperature from being in an unheated area and vibrations that the compressor will transmit through the floor. For vibration I can throw an isolation mat or mounts under it? I am however unsure of the affects it may have pulling in air from an unheated area, I could plumb the intake down through the floor if need be?
. I've got a friend who plumbed his in copper which is a viable option but I'm really liking the looks of these kits you can buy nearly anywhere that use what looks like Pex tubing and push on fittings. The ultimate option would be the aluminum kits I can get through our air system supplier at work but ?????? It's basically thin wall tubing, you borrow the installation kit which consist of a jig for holesawing the holes true then you simply install clamp on fittings, really nice setup.Anybody use the Pex kits? Any other suggestions?
