gas gauge
lorny
2:42 AM
ottawa
looks like new gas tank and gauge
when i fill up , the gauge will read quarter tank for about 20 miles than empty
ground at tank is good
how can i test gauge in dash
Had the same problem with mine, bought a new sending unit and pulled the old one to find the float had a hole in it. Floats can be replaced so before you buy a new gauge check the float.
Does the temp gauge work as it should! This will tell you the voltage limiter in the dash is fine.
Yep if you didn’t install in the car check it out first. Do an ohm check on the sending unit. Heard many stories that the new sending units don’t work right.
after market temp gauge don't know if one in dash work
Hey buddy, after complete restoration on 67 Gtx, and verified all correct and oem , gas gauge still not accurate, purchased a little electronic device from tanks inc , after reading about it on our site , inexpensive and works like a charm , easy install! Ck it out !
k thx
