Yes, you can have dual exhaust with the big tank but you have to use a much smaller diameter pipe if you want them to go straight out the back in the stock locations. With my 77 Cordoba with the big tank I directed the exhaust to the sides in front of the rear wheel. Looked cool...but I definitely want to go straight back this time on my Fury.
Yes, both tanks are readily available at most parts outlets....including Rock Auto. They have it listed under the Fury as well. Getting a tank isn't the problem. I just want to make sure that there aren't some other rinky dink parts, connectors, etc. to make this work that maybe aren't so readily available.
